Easiest Way to Replace Headlight Bulb
Old Dec 4, 2007 | 07:12 PM
cantdrive55's Avatar
Default Easiest Way to Replace Headlight Bulb
I know it sounds dumb but I am swapping out the high beam bulbs on my 2001 and it looks to me like you have to remove the entire headlight assembly to get to the bulbs? Am I right in that I have to remove the torx bolts out and then replace the bulbs? Sorry if its an easy answer.
Old Dec 4, 2007 | 07:15 PM
onepoint8tee's Avatar
Default RE: Easiest Way to Replace Headlight Bulb
No, the drivers side is simple. Remove the cap and the bulb is held in by a clip on the inside. To get to the cap on the passanger side you just have to remove the air box ducting.
Old Dec 4, 2007 | 09:06 PM
Cool thanks. After you said that I looked and felt dumb. Two little clips and about 15mins and I've got the new ones in. Thanks again.
rx7nwp
B8 Models
Nov 9, 2013 05:16 PM
vtraudt
Dec 4, 2010 10:32 PM
mb2audi
Nov 29, 2010 07:59 PM
MyDreamCar
Jan 5, 2009 09:42 PM
