ECU chips for A4
Old Mar 29, 2007 | 07:28 PM
mirwin's Avatar
Default ECU chips for A4
New to forum - I own an A4 1.8T quattro for a couple of years (bought new 2005)and love everything about the car except low end performace - can anyone recommend the APR Stage I ECU upgrade chip? Is it worth it to spring for the Stage I+ (extra $600 for injectors)? Any advice appreciated.
Old Mar 29, 2007 | 07:31 PM
Flip's Avatar
Default RE: ECU chips for A4
With APR Stage 1 you will definitely notice a difference. You should like low end now more than top end since the turbo is so small it trails off higher in the rpm's.
Old Mar 29, 2007 | 07:45 PM
rccks96's Avatar
You may be talking about the turbo-lag, which a chip will not help. You're just going to have to deal with that.
Old Mar 30, 2007 | 03:15 AM
fobyulous's Avatar
if your state doesn't check for emissions, get a test pipe, i remember reading that the turbo spooled alot faster with the test pipe in. Correct me if im wrong
Old Mar 30, 2007 | 10:18 AM
david9999's Avatar
APR1 is fine. Don't go the extra money for the injectors.
Old Mar 30, 2007 | 02:23 PM
rccks96's Avatar
ORIGINAL: david9999
Just curious as to why you'd say 'no' to the injectors?
LeM0N
Apr 23, 2008 10:37 PM
AdiInAnAudi
Apr 19, 2008 11:09 PM
daridari
Jun 26, 2007 07:12 AM
cary12
Mar 19, 2006 02:01 PM
kourosH
Mar 8, 2005 01:30 AM
