ECU fault in ABS unit
Old Jan 11, 2006 | 06:05 PM
az's Avatar
az
Default ECU fault in ABS unit
I have an Audi A4 2.8SE. The main display shows an error - the oil lamp and temperature icon alternately are displayed. At the same time as this happens the traction control and rpm counter are inactive. I showed the car to an Audi dealer who said "the ECU behind the dashboard needs replacing". I noticed that If I move the connectors on the ABS unit the fault sometimes clears. Someone else checked the car and confirmed there is a fault in the ECU in the ABS module and it needs replacing (so not what the dealer told me). The problem is that that unit is very expensive. Has anyone else had this type of error? What can I do? Where can I get a replacement ABS unit that is not the full Audi price? ( the refernce numbers are 0265 220 411, HR 8EO 614 111C HL, 866/15/06/5068)
Old Jan 11, 2006 | 07:15 PM
techbod's Avatar
Default RE: ECU fault in ABS unit
http://www.bba-reman.com/audifaults.htm
AUDI
Audi A4 throttle body failing
Audi A4 & A6 96-01 ABS Pumps commonly failing
Audi Quattro ABS Pump - 0 265 220 408
Audi TT dashboard failing
Bosch 0281 diesel ECU prone to causing lack of turbo boost
Audi Zexel aircon compressor failing
Detailed list of Audi faults
Audi idle speed problems
Audi strange vibrations and noises
Audi A4 fault codes
*2.6 and 2.8 litre cars with twin cat system, passenger side cat failing (probably due to thermal shocking from puddles)
some interesting stuff about the ABS system there
Old Jan 11, 2006 | 08:50 PM
az's Avatar
az
Ok- I will try that and see what happens.
legendrs1
Aug 19, 2015 04:18 PM
bradyhn
Jul 19, 2014 08:53 PM
philwill45
Dec 17, 2013 08:14 AM
DJ_OVERGOLD
Audi Q7
Mar 4, 2012 10:53 PM
Klittle
Feb 16, 2011 12:55 PM
