ecu SWAP
Old Mar 10, 2005 | 09:04 PM
NLT1.8T's Avatar
Default ecu SWAP
Anyone help me with the correct way to swap ecu?
Old Mar 10, 2005 | 09:06 PM
Jestnomen's Avatar
6th Gear
Default RE: ecu SWAP
Disconnect the battery, remove the cover and pull the ecu.
Install the new one and do a Throttle body alignment.
Old Mar 10, 2005 | 09:43 PM
ImolaS4's Avatar
Not sure why you include battery disconnect. I never disconnect. AWE doesn't
Old Mar 11, 2005 | 12:18 AM
david9999's Avatar
If you disconnect battery, make sure you have the radio code.
Old Mar 11, 2005 | 01:48 AM
Jestnomen's Avatar
6th Gear
I have always been tought to disconnect applied power before doing anything of this nature.
Old Mar 11, 2005 | 04:36 PM
NLT1.8T's Avatar
What will happen if you dont wait 3 min before tring to start?
Old Mar 11, 2005 | 04:44 PM
Jestnomen's Avatar
6th Gear
You mean waiting 3 minutes with the key in the ignition? the car may idle rough because the throttle body hasnt adapted.
o0hmikee
Oct 24, 2011 10:19 PM
HulkB5
Aug 8, 2011 09:21 PM
vtraudt
Jun 26, 2011 11:22 PM
impaler2383
May 17, 2006 11:29 PM
dtownhotcorner
Mar 18, 2006 07:20 AM
