Elim. 2871R Log
Old Mar 17, 2006 | 04:42 AM
aRIf's Avatar
Default Elim. 2871R Log
19psi, Elim 2871R, atp mani, atp 3" test pipe, atp 3" inlet pipe, borla, greddy fmic, 440cc green top, unitronic, ecs adj. fpr, vr6 maf housing.
I'm planing to turn the boost to 20-22psi. what you guys think? is it going to be safe to do that ?
Old Mar 17, 2006 | 04:45 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Elim. 2871R Log
this is where im a n00b but is it good to turn up the boost if your car is pulling timing? or is that such a small amout that its ok?
xx18quattroxx's Avatar
why is the timing in between your cylinders so inconsistent on the first run?... 4.5 degrees is not a lot but a decent number
you really aught to check out your egt before turning the boost up, for performance, one should use volume, not pressure to make power.
Old Mar 17, 2006 | 04:47 AM
Jeff's Avatar
ya thats what i was wondering why on the first run its not pulling timing on cylinders 1 ad 4 but it its on 2 and 3?
Old Mar 17, 2006 | 04:59 AM
aRIf's Avatar
second pull kind a going up hill, if it makes any different
what do you mean by EGT ?
Old Mar 17, 2006 | 05:07 AM
exhaust gas temperature, you want to keep it down, you have a big turbo that pushes a lot of volume... too much pressure will raise the temperature of the turbo and heat up your intake charge, nevermind that you have to retard the timing so far, and the exhaust being so hot will melt things you never thought possible... which would obviosly cause problems... its quite a large part of tuning, helps keep the intake temp down, which makes more efficient power, and the heat will mess up your air/fuel ratio.
Old Mar 17, 2006 | 05:13 AM
aRIf's Avatar
is there any number that is the lmit for the high or low temp ? I'll log that too see what is the temp of intake and exhaust.
Old Mar 17, 2006 | 05:15 AM
i think like 1200 is a slightly high, but ok running number, 1400 wont do too much, 1600 will melt your windshield haha, just kidding, but that is as high as the autometer gauges go, so you can just imagine...
Old Mar 17, 2006 | 05:21 AM
you will have to check around to see what is ok for these cars... and i dont think that the car can read the egt, so you will have to get a pyrometer kit to check it, but if i were you id check around to see how close you can have the timing with a safe amount of boost instead of blowing all the work and $$ you dumped into your car for a few months of fun. if you want an autometer pyrometer, i have a distributor account with them, prices are a bit better than normal. its like 129 + shipping for it. (ultra-lite 0-1600 deg F)
rallyaudi28
Apr 30, 2009 12:32 AM
MasterV
Jun 2, 2008 12:37 AM
aRIf
Apr 19, 2006 04:55 AM
aRIf
Mar 20, 2006 01:58 PM
aRIf
Mar 16, 2006 12:34 PM
