Engine bay is smoking...
Old Jan 10, 2006 | 07:14 AM
EvilA4's Avatar
Default Engine bay is smoking...
So, Im driving and I forget to put the hood down after checking a couple things. I stop and open the hood to find the engine bay is SMOKING a bit. Im not engulfed in smoke, I just see a tiny bit emiting from where the exhaust connects to the engine. Im actually in the process of selling the car and this is not good. What could it be? Thanks... Im really hoping this wont cost me alot.
Old Jan 10, 2006 | 07:17 AM
auDi1.8TQ's Avatar
Default RE: Engine bay is smoking...
i had the same problem...check your valve cover gasket, maybe your oil is leaking and hitting the exhaust pipe when its hot.... you probably need a new one.....
Old Jan 10, 2006 | 09:32 AM
BaconBait's Avatar
ORIGINAL: auDi1.8TQ
All I had to do was tighten the bolts.
Old Jan 10, 2006 | 01:17 PM
clconversion's Avatar
could be your cam adjuster gasket also good to replace when replacing the valve covers hopefully it is not the adjusters that is a expensive job
Old Jan 10, 2006 | 01:21 PM
Kellya4's Avatar
If it's the valve cover gasket you should be able to see oil around the cover, you may want to clean around the cover, and see if it leaks some more. I hope it's not the cam adjuster gasket as well.
Old Jan 10, 2006 | 05:11 PM
EvilA4's Avatar
Nope... it was the valve cover gasket. PHEW... Im glad it wasnt something worse.
Any tutorials on replacing one of those bad boys?
Old Jan 11, 2006 | 02:24 AM
EvilA4's Avatar
Any at all?
Old Jan 11, 2006 | 01:04 PM
aznknites's Avatar
There is a wite up in the DIY section...
sjbjtm@yahoo.com
Jul 14, 2010 03:59 AM
Joelt133
Mar 19, 2010 01:30 PM
turboAUDI77
Apr 25, 2007 12:44 AM
robmas
Apr 23, 2007 06:00 PM
josephrsalexander
Nov 26, 2005 10:57 AM
