engine code
Old Nov 5, 2005 | 06:21 AM
droo587's Avatar
Default engine code
Hey guys, just wondering if anybody would knowwhat the problem might be. I got a code P1136 Air/Fuel metering. I had them clear it but it came back after 2 days.
Andrew
Old Nov 5, 2005 | 12:11 PM
david9999's Avatar
Default RE: engine code
The problem is that clearing a code doesn't make the problem go away.
Check for Vacuum leaks, false air entry, or bad MAF.
Old Nov 6, 2005 | 02:20 AM
droo587's Avatar
ye si know, but im just wondering how i even check for it.. Anybody had this code thrown?
Old Nov 6, 2005 | 05:05 AM
david9999's Avatar
Hopefully, you know how to check for vacuum leaks.
For the MAF, you will need to borrow a VAGcom and check airflow readings.
Old Nov 6, 2005 | 05:08 AM
dankhound's Avatar
To check for a vacuum leak spray carb cleaner to suspected areas. If you have a scan tool you can watch for a change in o2 readings. Otherwise youll have to listen for the engine to change sounds.
xristos.greece
Aug 13, 2017 08:24 AM
HumbyWumby
Apr 4, 2013 05:44 PM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
spinedoc
Nov 3, 2008 12:12 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
