Engine Coolant Flush?!?! and Hydraulic fluid Qs...
Old Jan 3, 2007 | 04:42 AM
sautsinaga's Avatar
Default Engine Coolant Flush?!?! and Hydraulic fluid Qs...
Hi all,
My engine coolant level is a little bit low.
Is it okay if I just flush the pink stuff out and put some prestone coolant in?
Which prestone coolant will be suitable for my 1996 A4 Quattro?
Is 1 Gallon of new engine coolant will be enough to fill it up? can somebody tell me how to do it?
And also, I think I need to flush out my hydraulic fluid.
Can anybody also tell me how to change my hydraulic fluid and how much fluid do I need to fill it up?
Thanks....
Old Jan 3, 2007 | 04:57 AM
wood_e's Avatar
Default RE: Engine Coolant Flush?!?! and Hydraulic fluid Qs...
I wouldn't bother with fancy coolant in your 96. I'm running the green stuff in mine, but may switch over to yellow or dex cool when I do the timing belt in 45k.
Hydraulic as in brake fluid or PS fluid?
Old Jan 3, 2007 | 05:13 AM
Cruiserhead's Avatar
prestone makes a "all-compatible" anti-freeze. look for that, I believe a yellow bottle w/ action letters saying "All-compatible" hehe
Old Jan 3, 2007 | 05:14 AM
sautsinaga's Avatar
Sorry, I was reffering to Power steering.
What's the yellow stuff or dex cool? prestone 50/50?
thanks man..
Old Jan 3, 2007 | 09:24 AM
david9999's Avatar
[/align]
[blockquote]
Go to the autoparts store and look at the shelf for antifreeze.
For PS, you will need Pentosin 11S which you can buy from a dealer or on the net. To flush the PS system, you can disconnect the hoses to the pump and drain. Alternatively, you can do partial changes with a small turkey baster, suck out the fluid in the reservoir and replace with fresh Pentosin. Do not use transmission fluid or stuff labeled generic "power steering fluid". It will ruin your steering rack.
[/align][/blockquote]
Old Jan 3, 2007 | 02:45 PM
sautsinaga's Avatar
so, i assume that regular coolant will be fine for my car?
thanks
Old Jan 3, 2007 | 02:50 PM
tooxtreme8813's Avatar
regular coolant will be fine for your car as long as you dont mix it with g12
AudimaniaA4
Feb 22, 2009 10:20 AM
muckdawg24
Mar 18, 2008 01:36 PM
straitgame22
Aug 23, 2006 01:54 AM
thrax982
Mar 31, 2005 10:15 PM
