Engine fault codes ignition module??
Old Jan 25, 2008 | 04:14 PM
Jits7's Avatar
Default Engine fault codes ignition module??
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 906 266
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01051
Shop #: WSC 00000
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
17658 - Fuel Level too Low
P1250 - 68-00 - Cylinder 1
my dash also displays ln2 blinking, anyone got any ideas??
Old Jan 25, 2008 | 06:03 PM
dankhound's Avatar
Default RE: Engine fault codes ignition module??
The egr fault is most likely a plugged egr passage. Fuel level to low is probably a fuel level sensor with a bad spot on it. ln2 is your service light. Your due for service.
Old Jan 25, 2008 | 06:38 PM
Jits7's Avatar
Thanks for the help. So what steps would you reccomend to fix it lol thanks again for saving me time and money!
Old Jan 25, 2008 | 06:46 PM
dankhound's Avatar
You have to pull off the intake and egr pipe and clean the egr passages. Youd have to replace the fuel level sensor.
vassar007
May 26, 2010 05:25 PM
chapdiggy
Sep 18, 2008 08:01 PM
chapdiggy
B7 Models
Sep 7, 2008 07:52 PM
michaelh305
Jul 29, 2008 06:20 PM
BaconBait
Jun 30, 2006 01:54 PM
