Engine missing at idle
Old Nov 25, 2006 | 04:40 PM
Yaletown's Avatar
Default Engine missing at idle
I recently picked up a 2001 A4 1.8T. After the car warms up it tends to "missfire" while idling at a stoplight. Any ideas? I did a search of the forum but didn't find anything relevant.
Old Nov 25, 2006 | 05:23 PM
david9999's Avatar
Default RE: Engine missing at idle
Pull the codes. could be anything from a bad spark plug to a vacuum leak.
Old Nov 25, 2006 | 07:02 PM
CRAZYHAWK's Avatar
Could need a throttle body alignment.
Old Nov 25, 2006 | 09:00 PM
raimond's Avatar
...or throttle body cleaning...
Old Nov 25, 2006 | 10:24 PM
aRIf's Avatar
if the check engine light on, then pull the code from autozone or advance auto parts. they will do it for free. while you are there get yourself a new set of plugs NGK BKR6E.
Old Nov 25, 2006 | 11:54 PM
david9999's Avatar
Even if the CEL is not on there will be codes stored.
Old Nov 26, 2006 | 01:09 AM
scotia4444's Avatar
does it miss worse as you go up in rpm
it cold be that your sai is bad (letting air into your exhuast when deacelerating)
50mofo
Jul 31, 2015 10:05 AM
k_twiford
Mar 26, 2009 06:01 PM
Keithr726
Jun 9, 2008 07:00 PM
iceman2002_uk
Dec 23, 2006 10:03 PM
darrin
May 22, 2006 09:19 PM
