Engine Noise with Sound
Old Oct 19, 2007 | 09:54 PM
balkranjit's Avatar
Default Engine Noise with Sound
hey everyone
Latest problem i got is a wierd noise coming from the front of the engine, it use to be there but minor and now its has become worse, i think whatever it is its on its way out.
I attached a sound clip.
Little descrition.
I'm coming back from a quick drive around the neighbour too see if it goes away after car gets warmed ( car is now at normal driving tempt). Bascially when i get back into the garage i rolled down the windows, stuck my arm out while hood was closed. First 7 seconds or so of the clip im just in drive but at a complete stop, after that i put it into neutral as you can see the noise stops. then into reverse after 3 seconds, sounds back. then finally into park noise stops and i turned it off the recording. so whatever the problem is its only happening when im in a moving gear and only sounds normal when im in park or neutral.
The noise does start to settle down after car gets warm but still very loud.
I also attached a second clip where its the recorded right in the engine bay hood open while in drive.
Hopefully someone can tell me what it is its getting very annoying and would like to fix it.
Also its a 1998 A4 1.8T Tiptronic, only has Giac chip, 710DV, 3inch exhaust.
Old Oct 19, 2007 | 09:58 PM
The Bishop's Avatar
Default RE: Engine Noise with Sound
Need Linky.
Old Oct 19, 2007 | 10:15 PM
balkranjit's Avatar
sorry about that i can't find a spot that i can upload the mp3 files do you guys know where
Old Oct 20, 2007 | 05:41 PM
balkranjit's Avatar
sorry for the long wait i finally figured a site to do the linking
first file
http://www.fileden.com/files/2007/10...ghbourhood.mp3
second file
http://www.fileden.com/files/2007/10...n%20Drive.mp3\
let me know if it works or ill try to fix it.
Old Oct 20, 2007 | 06:16 PM
Audi_Skydiver's Avatar
I am assuming you are talking about the ticking noise?
Josh
Old Oct 20, 2007 | 06:20 PM
balkranjit's Avatar
yeah the major ticking now, i dont think its from the engine, but the belts fan alternator, i was hopeing someone had the same problem and knows exactly what it is. I know the audio quality wasn't that great.
Old Oct 20, 2007 | 06:22 PM
My car ticks all the time but it's just the valve train and injectors ticking along. i don't have any problems with it. But I am not sure what your problem is since it goes away when your not in gear.
Josh
Old Oct 20, 2007 | 06:37 PM
balkranjit's Avatar
you think it could be one of the belts or even the fan. i dont know much about engines but when searching on the site only thing i could think of was the tensioner spring failing and maybe thats causing all the noise.
markwilliamsnc
Feb 7, 2013 03:39 PM
NightHawk
Apr 25, 2011 10:10 AM
Papa_Dios
Nov 21, 2010 08:18 PM
tj19855
Dec 31, 2007 03:28 AM
jello
Nov 19, 2007 09:10 AM
