Engine Noise Help scraching belt noise?
Old Dec 25, 2007 | 03:30 PM
tj19855's Avatar
Default Engine Noise Help scraching belt noise?
Started my car the other night, Engine started making this noise, like the belt was scratching on something, what could it be? i just replaced my timing belt and all the components and serpertine belt but that was about a month ago and jut started doing thins noise.
http://s59.photobucket.com/albums/g3...t=CIMG2020.flv
Old Dec 25, 2007 | 10:00 PM
hiwords's Avatar
Default RE: Engine Noise Help scraching belt noise?
spray your serpentine belt with belt lube and see what happens
Old Dec 25, 2007 | 11:26 PM
ImTheDevil's Avatar
Make sure nothing is rubbing either, and double check the belt tension.
Old Dec 25, 2007 | 11:41 PM
auditech79's Avatar
How many miles are on it? Sounds like the water pump pulley is hitting the timing belt guard, it wouldn't suprise me if you were right at the 80k mark.
Old Dec 26, 2007 | 04:05 PM
tj19855's Avatar
94000 miles on it, i dont think is the guard i was trying to move it and nothing, ill try some wd40 see what happens
Old Dec 26, 2007 | 04:40 PM
auditech79's Avatar
94k? Have you don't the timing belt yet, cause your skating on thin ice.
Old Dec 31, 2007 | 03:28 AM
tj19855's Avatar
yes i replaced everything timing belt rollers ect serpertine belt... well i found out what it was my serpertine belt broke today. one of the rollers was shaking was not installed correctly and broke
kenman
Sep 12, 2012 02:34 PM
mr.kai
Oct 25, 2009 10:57 PM
tbrown
Sep 11, 2006 02:47 PM
