Engine Overheating ?????
Old Apr 16, 2007 | 09:40 PM
TankA4B5's Avatar
Default Engine Overheating ?????
If my engine is steady at around 200-225 degrees am i ok? It hasnt reached 250 but ever since I had my new exhaust put on it seems to be running hotter than it used to? As long as I stay below 250 am I ok?
thanks!
Old Apr 17, 2007 | 01:27 PM
LampyB's Avatar
Default RE: Engine Overheating ?????
I used to have a '95 beamer that always ran a bit hot. Took it to a mechanic and his heat gun said it was steady at about 220 degrees and that was totally fine. If it goes hotter than 225 there's probably something wrong. If you don't mind taking it in for diagnostics it might be worth your while, otherwise it shouldn't really cause harm.
LampyB.
Old Apr 17, 2007 | 10:56 PM
TankA4B5's Avatar
to the stealership i go
Old Apr 17, 2007 | 11:31 PM
Amze's Avatar
Why is everyone stealing... "Sooks?" if thats the moderator guy.. think I'm wrong..
But why is everyone stealing one of our moderaters Avatars... da **** has got to stop![&:]
Old Apr 18, 2007 | 03:43 AM
TankA4B5's Avatar
thanks for the help
Old Apr 18, 2007 | 08:59 PM
b.hasz's Avatar
you could also just try replacing your thermostat. that is not expensive at all. about 10 bucks. and you can do it yourself. that may be the problem
Old Apr 19, 2007 | 10:58 AM
quattrosedan's Avatar
Tank, how do you know your car is running 250F? Are you looking at the lower left OIL temp gauge? Because that is not the same as your coolant temp guage. If it is your oil, you may have a problem with your cooler.
Old Apr 19, 2007 | 09:42 PM
TankA4B5's Avatar
Im looking at the lower left temp gauge. Are there any signs of the cooler going out? thx.
Solarisshiva
Apr 22, 2014 11:57 AM
redrhino
Oct 19, 2011 10:53 AM
bauer1185
Apr 13, 2010 11:59 PM
krazyfox09
May 25, 2009 01:17 PM
ldtikk
May 1, 2007 02:52 PM
