ENGINE OVERHEATING
Old Apr 30, 2007 | 06:51 PM
ldtikk's Avatar
Default ENGINE OVERHEATING
2000 A6 4.2-V8 engine overheating.
What can be the problem? thermostat, water pump, radiator clogged, fan nut running.
Any other?????
Thermostat change; do we need remove timing belt for that??
If remove, we need to change now, I have 74kmile.
What else we need to change with early timing belt change??
Old Apr 30, 2007 | 08:30 PM
mustang196718's Avatar
Default RE: ENGINE OVERHEATING
does it stay cool while you're moving, or does it overheat then also? if not, then it's probably the fan. if it still over heats, either something is plugged, ie radiator or thermostat stuck, or worse you're water pump is shot. go here, scroll down towards the bottom for timing belt kits, they come with everything you need: http://ecstuning.com/stage/edpd/page...ategory=Timing
Old Apr 30, 2007 | 09:51 PM
ldtikk's Avatar
Thanks your advice. problem came up when i drove home with 50 mph on a low traffic road, overheating warning light came up. I stopped, idlering 1 minutes and stopped the engine. Waited 5 minutes, I turned heater on, drove half mile, warning light again, and pumpng out some coolant from the reservoir.
Above timing belt, thermostat and water pump, what else I need to change? Belt tensioner etc? Thx.
Old Apr 30, 2007 | 11:29 PM
SSn's Avatar
SSn
Get a kit from Blauparts, it has everything you need to change, and even extra (cam/crank seals) =)
You do need to replace timing belt everytime you take it of iw it has been used for longet then 15 minutes, I think
Old May 1, 2007 | 07:20 AM
ORIGINAL: ldtikk
it's not a belt tensioner because the water pump is driven by the timing belt, and if a tensioner was bad, you're car wouldn't be running right now. things that this immediately makes me think of would be either a plugged radiator (do you run the recommended G12 fluid?), a stuck thermostat, or a broken water pump. there's always the chance that something could be stuck in a coolant line somewhere, but i doubt that.
Old May 1, 2007 | 07:23 AM
in either case unfortunately, it sounds as though you might have to be pulling the timing cover off, so you may as well change the timing belt and all that jazz since you're already gona be in there and it is starting to get about that time. 74k miles, if i had to take the timing cover off, i'd definitely be replacing as much as i could while i was in there.
Old May 1, 2007 | 02:52 PM
2k S4's Avatar
It can be a clog in the line some where, or a failed thermostat. If you have to drive it, turn the heat on FULL blast it will help cool the engine a bit.
One way to check is run the car, till it get just a tick past center, then feel the radiator, or use a IR thermometer. If it's cool, then it's not getting coolant, & might be the thermostat, or a clog.
The other thing, is you might have a plastic water pump, & the blade might have failed. You can loosen the bleed screw by the throttle body, & see if coolant flows out of it, do this on a COLD engine. No pressure there, no pump.
If it is the thermostat, then your looking at the TB job, since it's behind the TB.
Solarisshiva
Apr 22, 2014 11:57 AM
redrhino
Oct 19, 2011 10:53 AM
bauer1185
Apr 13, 2010 11:59 PM
krazyfox09
May 25, 2009 01:17 PM
TankA4B5
Apr 19, 2007 09:42 PM
