Engine Repair
Old Nov 4, 2004 | 03:28 AM
TetrickA4's Avatar
Default Engine Repair
I have a 98 A4 2.8L quattro and I havent done anything to the engine yet. Im thinking about the supercharger and other mods like a chip and intake but what should I get done repair wise before I actually start with the mods. I only have rims, exhaust, and lowering kit. Can yeah all help me out because I keep reading about changing the timing belt and water pump??
Old Nov 4, 2004 | 08:35 AM
david9999's Avatar
Default RE: Engine Repair
Before you do mods, do basic maintenance.
How many miles? What transmission?
When is the last time you changed the plugs and filter? Brake fluid bleed every two years, If tip, drain and fill the transmission fluid. If high mileage change the differential gear oil.
If over 60K miles, time for a timing belt, tensioner, water pump and front engine seals.
Might want to switch out some of the PS fluid too. Only use OEM or Pentosin CHFs11. My NAPA auto parts actually carries the Pentosin.
Control arms and brakes OK? CV boots? Wheel Bearings?
Chip doesn't give much additional power on a 2.8.
Old Nov 5, 2004 | 03:47 AM
99a4audi's Avatar
before u spend all that money make sure ur car has all the maintence done. u dont want to spend all ur money and need it for oil or something else. i suggest exhaust, chip, sup-ercharger if u can afford it ($5000). have fun
zx12arrgh
B7 Models
Sep 5, 2013 09:05 AM
binco
Oct 1, 2012 01:06 PM
tdepirro
Jan 19, 2011 03:28 PM
vangb2
Jul 24, 2010 12:16 PM
johnnysd
Jan 10, 2009 01:32 PM
