Engine smells like something's burning...
nope thats the wrong one. that's the crankcase breather hose which is run by the secondary air injection pump i believe. ima go get a pic for u. and sry bout the vac line comment lol i was not myself.
the circle is the line u need to pull. it has a one time use clamp on it which is a PITA. make sure u have new ones to replace them. the arrow is direction of flow to intake mani.
hiwords, I really appreciate your help, I'm going to run to the store and pick up some hose clamps before I disconnect that.
I've found where the smoke and smell is coming from, again on the passenger's side behind the engine. here's some pics:
You can kind of see that grimey dirty, wet looking stuff around there, which is what I believe causing the smoke and smell.
lmao do u think ur first pic is large enough? im not very sure wut that thing is called though. im still trying to figure out wut all those valves are on my car too. PM auditech79 and he'll tell u
Thanks, I'll do that. yea I forgot to resize the pic until after I posted it haha.
I took the one time use clamp off of the vac line, but to my surprise, I have zero suction through the plastic fitting the vac line rubber tube goes over. That's the correct spot for sure? Is there any reason I wouldn't have suction through there?
I had the same burning smell/smoke issue with my '98 Passat 2.8 V6. The valve cover gaskets were leaking and oil was getting on the hot exhaust pipes.
It wasn't a coolant leak issue since the level in the reservior bottle never decreased.
Hope this helps.
Hope this helps.
