Engine smells like something's burning...
Old Oct 7, 2007 | 11:54 AM
bryan0's Avatar
Default RE: Engine smells like something's burning...
I don't think i ever smelled metallic bacon haha but I guess it smells something like that.
Old Oct 7, 2007 | 12:01 PM
hiwords's Avatar
nope thats the wrong one. that's the crankcase breather hose which is run by the secondary air injection pump i believe. ima go get a pic for u. and sry bout the vac line comment lol i was not myself.
Old Oct 7, 2007 | 12:23 PM
hiwords's Avatar
the circle is the line u need to pull. it has a one time use clamp on it which is a PITA. make sure u have new ones to replace them. the arrow is direction of flow to intake mani.
Old Oct 7, 2007 | 01:01 PM
bryan0's Avatar
hiwords, I really appreciate your help, I'm going to run to the store and pick up some hose clamps before I disconnect that.
I've found where the smoke and smell is coming from, again on the passenger's side behind the engine. here's some pics:
You can kind of see that grimey dirty, wet looking stuff around there, which is what I believe causing the smoke and smell.
Old Oct 7, 2007 | 01:34 PM
hiwords's Avatar
lmao do u think ur first pic is large enough? im not very sure wut that thing is called though. im still trying to figure out wut all those valves are on my car too. PM auditech79 and he'll tell u
Old Oct 7, 2007 | 01:59 PM
bryan0's Avatar
Thanks, I'll do that. yea I forgot to resize the pic until after I posted it haha.
I took the one time use clamp off of the vac line, but to my surprise, I have zero suction through the plastic fitting the vac line rubber tube goes over. That's the correct spot for sure? Is there any reason I wouldn't have suction through there?
Old Oct 7, 2007 | 02:11 PM
techbod's Avatar
sounds like a coolant leak ( lets not get confused ) investigation required
Old Oct 7, 2007 | 03:37 PM
  #18
tam92's Avatar
I had the same burning smell/smoke issue with my '98 Passat 2.8 V6. The valve cover gaskets were leaking and oil was getting on the hot exhaust pipes.
It wasn't a coolant leak issue since the level in the reservior bottle never decreased.
Hope this helps.
Old Oct 7, 2007 | 05:16 PM
  #19
hiwords's Avatar
did u do this? take the bottom clamp, in the circled pix, off, turn the elbow so the hole is upwards and then start the car
Old Oct 7, 2007 | 06:47 PM
  #20
mark_2328's Avatar
I'm getting like a sweet smell after I run the car hard and stop. No smoke though. Might be coolant?1.8T btw. Any suggestions?
