Engine stopped - please help
Old Oct 13, 2018 | 11:56 AM
user 354787987's Avatar
Banned
Default Engine stopped - please help
My 2005 Audi Quattro 2.5 tdi Auto was running perfectly when suddenly, at quite high speed going uphill the engine cut out without warning. No hiccups, no misfiring , just stone dead.
No warnings appeared on the dash though when I was trying to restart I saw the glow plug light flashing at one point.
The rescue guy squirted something into the air intake and it started for a few seconds then nothing. After being carried home I checked the fuel pump fuse then loosened a pipe on the fuel filter and found that fuel is flowing when ignition is on but with no amount of cranking will it even try to fire.
Any advice / guidance will be greatly appreciated -- thanks in advance
Old Oct 13, 2018 | 12:02 PM
Banned
Default oh I forgot to mention
I forgot to mention I have run VAG.com engine controller which did not produce any fault codes . The car has done about 140k miles and had a cambelt change a couple of years ago. Prasent usage of the car is very light as I am now retired.
Old Oct 30, 2018 | 03:33 PM
steve.massiah's Avatar
Angry
I'm also getting similar problem from my same model. Though I try to get exact solution from seller but didn't get yet from their end If you find any information please share with me. Thanks.....
Daftbob
Feb 14, 2014 08:31 PM
jazzo
Jan 3, 2014 05:41 AM
20090401
Oct 4, 2012 05:46 PM
tjcinco
Jun 12, 2006 05:45 PM
