Check Engine Light / Re-Start problem
I could sure use your help. My 92' S4 starts fine. While driving, the "Check Engine" light will come on for a bit, then go off. It may come back on depending on how long I drive. The car seems to run fine, until I Switch off the ignition. When I try to re-start the car, it will not! Almost seems like the fuel pump stops working, because the car turns over but there is either no spark, or fuel.
After letting it sit and cool down(usually in about 1 1/2 hours) the car starts up again, like nothing was ever wrong. Until I turn it off again and the symptoms repeat again. Very Frustrating.
I took the advice of the operations manual and shunted the contacts inside the fuse box in the engine compartment, for the specified time. The "check Engine" light flashes for awhile, but the display will not generate a code which throretically should tell me what component in the Emissions System has failed. Do you know what problem my car has???
Please Help!
Please Help!
Isramirez21
Jan 24, 2013 05:07 PM
Baumee8
Nov 18, 2006 10:49 PM
Baumee8
Nov 11, 2006 01:36 AM
