everything is breaking apart.
Power door locks stop working, checked fuses they are all ok even though I have not been able to get a correct fuse diagram for a 1999 Audi A4.
(What is the actual name of the Pump that I probably need to get and is it a hard to do self install?)
Fuel Gague is acting up, going up and down! What is causing this, Bad sensor?
My drivers side window was acting up until it got stuck half way and then all of a sudden you hear something breaking off, screws falling to the bottom and the window just dropping down straight through.
And also my sunroof was acting up and while going back it broke all the brackets of the inner sunroof cover.
I almost forgot to mention my rear virw mirror broke off and now I have to get the entire piece, anyone know where I can find this cheap?
Pure Misery!
Pure Misery!
ORIGINAL: FIUPike83
Pure Misery!
Pure Misery!
-Fuel sending unit
-plastic window clips + add some grease
- clean the channel there is a DIY on 1 of the Audi sites for cleaning the sunroof channel. But you will need toreplace the bracket also. [&o]
