Evidently my car is only supposed to run 13psi.....
Old Jan 26, 2007 | 04:03 AM
Philthykins's Avatar
Default RE: Evidently my car is only supposed to run 13psi.....
i dunno, i have yet to hit 18 anymore, i dont spike higher than 15psi. and thats onlyin first gear.
Old Jan 26, 2007 | 04:06 AM
onepoint8tee's Avatar
Come to Columbus again sometime and we'll meet up and have a looksee if you dont figure anything out.
Old Jan 26, 2007 | 05:35 AM
AteUrV8's Avatar
ORIGINAL: onepoint8tee
If its true that you had revo, i have read that once you get revo there are issues if you try to get reflashed with another brand chip.
i think thiscould be the problem.. how positive are they that you previously had revo
Old Jan 26, 2007 | 05:48 AM
not sure they just said i might have had it on.
alright onepoint8tee, ill pm ya the next time i head down. thanks
Old Jan 27, 2007 | 03:39 AM
i think i know my problem, im thinkin since my car has 135k on the odometer the turbo is a bit wore out from never being rebuilt. i might just get a newer k03 or rebuild mine
Old Jan 27, 2007 | 11:27 AM
david9999's Avatar
My K03 has 165k miles and holds 15. If you are looking for 15 at redline you can forget about a K03. They run out of steam above 5000 rpm.
Have you checked your diverter valve?
Old Jan 27, 2007 | 02:03 PM
AudiTurbo's Avatar
MINE wont hold over 15 psi over 5k..I changed my dv to the forge 007, and i still dont hold all the boost until redline.
Old Jan 27, 2007 | 09:47 PM
  #18
AudiTurbo's Avatar
I think it could be the forge 007....I have heard a lot of people having trouble out of them
Old Feb 7, 2007 | 03:05 PM
  #19
patty AT forge's Avatar
AudiTurbo,
Your problem existed before installing the 007 and you are pointing to it as the cause? Or am I misunderstanding something?
Exhausts do indeed have a dramatic effect on turbo cars.
A spike followed by gradually dropping boost is normal on a stock turbo'ed 1.8t. that being said your boost still seems low. Try the test I posted in your other thread to determine if the valve is sealing, if it passes might I suggest you looking at your N75? Or your turbo may be on its way out.
jmsflynn
May 9, 2011 11:27 AM
MartinCieslak1
Apr 10, 2010 07:35 PM
defaz
Apr 22, 2009 12:57 PM
ARCTIC A6
Dec 22, 2008 12:11 PM
ImTheDevil
Jan 8, 2008 04:16 PM
