View Poll Results: A poll
EvoMS
55.56%
Carbonio
44.44%
Voters: 18. You may not vote on this poll
EvoMS vs Carbonio intake
Old Nov 13, 2007 | 07:30 PM
Leifer's Avatar
Default EvoMS vs Carbonio intake
So it's high time for me to replace the stock intake, because it's a piece of ****. I'm trying to decide between the Carbonio and the EvoMS intake; but I can't fiure out which one I'd rather have. On one hand, the EvoMS is $289.99 + tax + SH, which equates to something like $330, whereas the Carbonio can be bought for $329.99 + tax (I can pick it up from the place that sells it). So, if you were in my comfortable slippers right now, what would you do? I like the enhanced DV noise of the Carbonio, but can I get the same results from the EvoMS as well?
Old Nov 13, 2007 | 07:32 PM
cincyTT's Avatar
I'm make believe
Default RE: EvoMS vs Carbonio intake
Personally i would go with
1 - 2.75" coupler
1- 2.75" U bend pipe
and then slap this on the other end
All in all should cost about $130 and be an intake worth having.
Old Nov 13, 2007 | 07:36 PM
socaljoe's Avatar
SoCal Crew Member
Too much money for little performance gain (if any at all). Just get a K&N drop in filter and save $$$
Old Nov 13, 2007 | 07:37 PM
Leifer's Avatar
ORIGINAL: cincyTT
1 - 2.75" coupler
Haha, if I knew what I was doing, I'd totally do it. Unfortunately, I'm going to have to request help to even install the intake that I buy, so making my own would be impossible. But I'll pay you if you can make that intake and mail it to me!
Old Nov 13, 2007 | 07:38 PM
onepoint8tee's Avatar
Hmm....
Waste of money
or
Bigger waste of money.....
The stock intake is about as good as it gets. If you like the psshhh noise an itake will give you, then, whatever. Just know the air you suck in is not colder, it is hotter, and you will lose some low end tq and gain some breathing air at 7k rpm's. That is all.
Old Nov 13, 2007 | 07:39 PM
Leifer's Avatar
ORIGINAL: socaljoe
I'm getting a new exhaust, as well as a bigger turbo, so the intake is necessary. Plus, I already have a K&N drop in filter
Old Nov 13, 2007 | 07:47 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: Leifer
ORIGINAL: cincyTT
1 - 2.75" coupler
It will be as simple as removing the box, add in a U pipe and then installing the filter on the other end.
Here you go,
connect this to the maf
connect this the the maf and filter. Then your done. I even shopped for you
Old Nov 13, 2007 | 08:00 PM
ORIGINAL: Leifer
ORIGINAL: socaljoe
Which turbo?
Old Nov 13, 2007 | 08:02 PM
Leifer's Avatar
GT28RS.
Edit: you thought I was going to say "that one k03 that kemp_travis linked me on ebay it looks sooooo powerful" right? Hahaha.
Old Nov 13, 2007 | 08:03 PM
Rofl... You could fit the stock airbox with that turbo. Go ahead, I DARE you!
Nah. Do what cincy said. I think you could easily spend less than $100 though for just the intake. Get one of those audizine heat shields too.
