exhaust/muffler taking leaks and burping..
Old Sep 28, 2006 | 12:32 AM
RollinA4's Avatar
Default exhaust/muffler taking leaks and burping..
when I start my car I always get a puddle of water that came out of the muffler. I have had the car stored for couple months but been starting it regularly. When I finally move I hear this sort of fair gurgling burping from the muffler/exhaust. This sound is loudest right when I shut off the car, and ALWAYS when I shut off the car.
Today I was revving the engine a bit for quite a while, up to 5k and when I checked there was a pretty big puddle of water running on the ground which I never get to see drip.
I posted about this already, however not with enough information it seems. Now, what can we say the problem is, and what is the solution.
Gas been in there for couple months, but like I said been turning it over regularly. Thanks for looking, Im sure Ill get some good advice here
Old Sep 28, 2006 | 12:40 AM
david9999's Avatar
Default RE: exhaust/muffler taking leaks and burping..
You have a muffler full of water, either from driving through deep water, or more likely due to running the engine for very short periods during storage. To get rid of it put in fresh gas and go on a long trip that get the exhaust hot and evaporates the water.
I am assuming that you have checked your coolant level and that you aren't loosing coolant through a bad headgasket.
Old Sep 28, 2006 | 01:11 AM
RollinA4's Avatar
yes, I have had it stored since April and only been starting it up long enough to get the engine warm. When I start the car up there is a bit of white vapour which goes away fairly quickly, so that should be normal and not a bad head gasket, when I was revving the engine vapour comes back... but again, normal right? water in the muffler... this could make sense, this sound did not happen BEFORE I've just kept it in storage and is fairly recent, so again, I don't see why a head gasket would have gone bad. My collant level is fine, right where it's been and where its supposed to be. You think this is the definite answer? Water in the muffler will cuase this sound whenever I shut off the car? Thanks for your input bro
Old Sep 28, 2006 | 01:51 AM
dankhound's Avatar
Considering your not losing coolant its most definatly water. Burning coolant will also give the exhaust a sweet smell. The gurgling is probably air flowing thru the water. Just take it for a nice long drive like stated above and that should take care of all your problems.
Old Sep 28, 2006 | 02:40 AM
RollinA4's Avatar
you people are very helpful
But if anyone else has any more ideas or suggestions I would love to hear it
Old Sep 28, 2006 | 04:40 AM
AudiCross's Avatar
Yes, water could be there from wet driving, or just from condensation. if you cant take it out of storage, just start the car and let it idle for a good while. but make sure it doesnt over heat. doing this will heat up your exaust/muffler to blow out/evaporate the water currently in there. i dont know what exaust system you have, but water in there isnt good if it sits. it can rust out your pipes and muffler changing the tone and performance. IF possible, get your car on like a steep hill if you cant drive it and run it there while keeping an eye on engine temperature if running for a long period of time.
kind of a funny note on this, when my dad was in highschool, he got new mufflers for his mustang becuase they were required, but he then filled his mufflers with water as to rust them out (they were glass packs, so it made a huge difference)
oh the stupid things he did to get a 12.3 second mustang...
Old Sep 28, 2006 | 03:19 PM
RollinA4's Avatar
I have the standard exchaust/muffler that comes with 98 A4 2.8 quats.. you guys seem to be on the money here
Thanks for the input guys
Old Sep 28, 2006 | 07:22 PM
RollinA4's Avatar
THANK YOU ALL VERY MUCH! THE ENGINE BLEW UP THANKS TO YOUR ADVICE [:@]
jk.. great advice, it worked perfect. You guys are great, hoorah for audi forums
Thanks again for the input
harveya4
Apr 28, 2013 09:31 AM
RedSox111
Jan 9, 2008 01:15 AM
dans93audi90s
Oct 28, 2007 12:17 PM
metalmulisha
Oct 9, 2006 06:16 PM
brent07
Sep 12, 2005 05:14 AM
