Fault Code Diagnosis & Repair
Hi
Could someone who's tech certified or experienced in this matter please lend some assistance.
17887 - Brake Boost Vaccum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
I'm assuming theres a leak in a vacuum line, how do I go about finding the problem and rectifying it.
Thank you.
Thank you.
17887/P1479 possibly your vacuum pump failed, needs to be checked out, or this is what searching the form can get you https://www.audiforums.com/m_364038/tm.htm
008, 17887, 2002, a4, audi, code, diagnosis, fault, fix, how20to20fix20p147920code, implausible, intermittent, p1479, p1479008, signal
