Few Questions HELPS NEED
Old Sep 10, 2007 | 11:24 AM
AudiMasterpiece's Avatar
Default Few Questions HELPS NEED
I just ordered a set of OEM RS4 wheels with Audi Center cap on http://www.ecstuning.com/
It syas online that the wheel is 19 x 9 but i wonder if it fits into my A4 3.2 Quattro.
and if the fitment is right what size of tire should i get? 255/35 19?
just for saying that i live in Boston, MA so i definately gonna get all season tires.
btw ECStuning.com is a very good place to order almost every OEM parts for Audi and VWs.
I got my OEM carbon rear spoiler with only come with 25th anniversary limited S4s
(unless u could get a DTM version of A4 which only came out in Europe. :[)
I need your advise dudes. Thanks!!
Old Sep 10, 2007 | 02:40 PM
Adam@mvp's Avatar
Default RE: Few Questions HELPS NEED
The 19x9 is going to be pushing it because you have your upper control arm or link that connects around that area and you dont have much to work with. You would probably have to put a 1" spacer or something like that and roll your fenders. You would probably be able to fit a 19x8 wheel under there no problem, you just have a lot of issue with the inside clearance.
Stock 18x8
43mm offset
5x112 Bolt Pattern
Hope this helps!
Adam~
daze614
Jun 21, 2023 08:15 AM
jzstuggie
Jun 4, 2008 06:20 PM
707782y
Dec 8, 2007 07:57 PM
alnsa4
Nov 3, 2007 01:05 PM
