f'in coolant flange
Old Nov 6, 2007 | 05:26 PM
chaos92287's Avatar
Default f'in coolant flange
ok so even after i replaced my leaking coolant flange, ITS STILL LEAKING[:@] i guess the o-ring isn't forming a good enough seal, is there anything i can put between the flange and the engine to stop the leaking?
Old Nov 6, 2007 | 05:34 PM
hiwords's Avatar
Default RE: f'in coolant flange
coat the o-ring in blue rtv. but not too thick. get excess coolant out so the rtv doesn't get wet. then stick it in. then put sum rtv around the outside
Old Nov 6, 2007 | 05:35 PM
Fier Ringe's Avatar
Default Coolant flange
You just have to replace the flange and the o-ring and clean the sealing surface of the head and it should seal up okay.
www.avalonmotorsports.com
Old Nov 6, 2007 | 05:38 PM
chaos92287's Avatar
Default RE: Coolant flange
i already replaced the flange and cleaned the back of the block, but ill try that blue rtv stuff, thanx
Old Nov 6, 2007 | 06:28 PM
auditech79's Avatar
Told ya they suck
Don't put any blue RTV on that seal, that seal is designed to turn into a square shape when pushed into the head so adding RTV will make it leak more in the long run.
You just need to use some o-ring assembly lube when installing the ring so it won't pinch. I gaurantee you when you take it out there will be a small knick.
Old Nov 6, 2007 | 07:41 PM
99A4NOW's Avatar
I'm still having problems with mine too. I also replaced both the o-ring and the flange. The only way I was able to slow it down was to cut a slot in the mounting tab of the metal tube that runs from the flange to the upper radiator inlet. It seems that when I was putting that bolt in the metal pipe was flexing that cheap plastic flange and causing it to leak. Once I cut the slot in the tab it allowed the pipe to rest where it wasn't flexing the flange anymore. Might be worth it to check that out.
Old Nov 6, 2007 | 07:55 PM
chaos92287's Avatar
ORIGINAL: auditech79
Told ya they suck
where do i get o-ring assembly lube?
Old Nov 6, 2007 | 10:43 PM
auditech79's Avatar
You can get that at any autoparts store i think, i always get it from the parts department so if you need to go to audi.
Old Nov 7, 2007 | 01:46 AM
chaos92287's Avatar
alright thanx man
judeman
Apr 7, 2012 04:46 PM
cpageIII
Sep 21, 2011 04:00 PM
yellow_submarine
Jul 22, 2011 09:49 PM
ckappler
Nov 23, 2010 08:56 AM
less_of_me
May 2, 2007 03:29 AM
