Finally took my engine covers off
Old Nov 16, 2006 | 02:17 PM
LME's Avatar
LME
Default RE: Finally took my engine covers off
Yeah, your smell probably comes from leaking valve covers. If it gets worse, you can easily lose a significant amount of oil on long road trips... and when you run low on oil, you'll start to gum up your cam shafts... then it's the oil pump going... then you have to call me and get a CARFAX mileage verified low mileage engine...
And I would rather not have you as a customer
Get your valve cover gasket checked and replaced
Old Nov 16, 2006 | 02:33 PM
aRIf's Avatar
accually, you can wash the engine bay. buy a engine cleaner and a small brush. sprey it all over the engine (watch out the electrical parts. cover them before you start the clean the engine) then brush it nicely. then use water to clean.
Old Nov 16, 2006 | 02:57 PM
GeilKyle2's Avatar
g12 coolant!
Old Nov 16, 2006 | 04:03 PM
LME's Avatar
LME
You can wash that stuff off... but if you leave it on a while it won't look pretty.
Old Nov 16, 2006 | 04:25 PM
techbod's Avatar
I dont see any oil leak apart from the right side rocker cover where oil has been spilled while topping up - rattle for a few seconds is normal with cold engines till the oil gets round and will go quiet very quick if you use good oil - serpentine belt guide pulley/tensioner is doing more of a rattle and needs to be checked out before it gives out - coolant is low so that's probably where the smoke is check for leaking coolant pipes
kduznetsov
Oct 3, 2012 01:20 AM
jt's A4
Nov 10, 2009 10:27 PM
TT4fun
Aug 6, 2008 08:56 AM
diehlryan
Apr 20, 2007 05:34 PM
lurkerpika
Nov 4, 2006 03:06 AM
