Fixed my car but its not workin as well as it should.
Old Jul 13, 2007 | 01:09 PM
Noobinator's Avatar
Default Fixed my car but its not workin as well as it should.
Ok it took me about 3 weeks to figure out what was wrong with my car and now I finally fixed it. Now aside from needing to have my boost controller set, the car runs fine but sometimes the car smokes and its worryin me. Theres not check engine light but I am getting 3 codes. One is 17956 because I am running no n75 valve which is irrelivent. I was wondering if the other two codes could be causing the smoking? And how do I fix these problems?
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High : P1113
16795 - Secondary Air Injection System (B2) - Incorrect Flow
or Secondary Air Injection System: Incorrect Flow Detected : P0411
Incase it helps I have a 2000 A4 1.8Tq runnin BT setup and a catless exaust.
Old Jul 13, 2007 | 01:57 PM
Noobinator's Avatar
Default RE: Fixed my car but its not workin as well as it should.
Anybody?
Old Jul 13, 2007 | 02:04 PM
CLX's Avatar
CLX
Zombie Defense Force
What color is the smoke?
Old Jul 13, 2007 | 03:10 PM
ironman's Avatar
the first one is Oxygen sensor passanger side of the rear cat, if the smoke is blue it could be a head casket issue, does it smoke nder WOT, or whenever, check to see if you have any oil in the Turbo it maybe that. If you arnt running a cat dont worry about the cat Fault i didint see the bottom of your post. it may need to be grounded to the one in front of where the cat was.
Old Jul 13, 2007 | 03:16 PM
cincyTT's Avatar
I'm make believe
smoke color and from where is a good thing to know. The passat had a bad valve cover gasket and that thing smoked really bad... and really stunk. If your blowing it out the exhaust, you have a bigger problem.
Old Jul 13, 2007 | 08:18 PM
Noobinator's Avatar
It is like a bluish whitish smoke that only smokes on sometimes. Smoke is coming out of tailpipe. I did notice when I took off my intake that there was oil pooling in the turbo inlet.
[IMG]local://upfiles/36255/4FE2A4FACA184F7FB3356CD88E82E3DA.jpg[/IMG]
Old Jul 13, 2007 | 08:20 PM
CLX's Avatar
CLX
Burning oil FTL
Old Jul 13, 2007 | 08:31 PM
aRIf's Avatar
wow wow wow.... you can swim in that oil.... hope that oil is not coming from turbo... get rid of from that oil first. then run the car for 10mins and chech again see if you get more oil.
you also consider to have oil catch can. I think you have apr inlet ha?
a12gaugehug
Mar 28, 2011 06:06 PM
01AudiA4
Apr 17, 2008 02:24 AM
auntsally
Jan 30, 2007 10:46 AM
ecefunding
Jul 23, 2006 05:57 PM
BFlan2001
Aug 12, 2005 09:57 PM
