Flat Tires?
Old Dec 30, 2006 | 04:36 PM
trolytic's Avatar
Default Flat Tires?
Hi, I have an 05 quattro converable which isgetting flat tires on a regular basis (7 this year). A few haveoccurred because of sharp turns, while another resulted fromrunning over areflector while makinga lane change on the freeway. Notonehas resulted from asharp object such as a nail, knife, or such.Is there something I should know?
Old Dec 30, 2006 | 06:52 PM
xAUDIx's Avatar
Default RE: Flat Tires?
Where are the holes? Are they side wall rips? You might wanna invest in some run-flats IMO
Old Dec 30, 2006 | 08:07 PM
tooxtreme8813's Avatar
you could have a bent rim
Old Dec 30, 2006 | 09:49 PM
Cruiserhead's Avatar
is it always on the same wheel? i agree with tooextreme, it sounds like a damaged wheel. Maybe a defect in the lip where the bead is not sealing correctly-just a guess
either that or you have incredibly bad luck!
Old Dec 30, 2006 | 09:51 PM
DENIS415's Avatar
+2 for the messed up rim...hurry and get it checked out!
Old Dec 31, 2006 | 12:17 AM
ImTheDevil's Avatar
Agreed also - if you have a bad bead seal, it won't hold the air pressure right, and anything to stress the tire (ie, hitting something, hard cornering, etc) could cause it to leak down. Have the offending wheel checked throroughly - remove tire, inspect wheel, even put the wheel (with the inflated tire on it) into a water bath and watch for bubbling to see if you have a bead leak.
Alfon99
Dec 27, 2013 11:58 AM
gprace
Mar 24, 2013 09:05 AM
audi_sf
Dec 20, 2008 08:27 PM
Papachristou
Jul 25, 2006 02:25 PM
pingapid
Mar 2, 2003 08:11 PM
