Fluid Question. Need Help.
Old Jan 29, 2008 | 08:50 PM
Iceman04503's Avatar
Default Fluid Question. Need Help.
My car is leaking a yellow fluid. I think it might be coming from the driver side close to the front wheel. But I have the belly pan under my car so it might just be from somewhere else. Does anyone have any idea where the fluid might be coming from? I think it might be the transmission so i have no idea. Please Help! -Van
Old Jan 29, 2008 | 09:02 PM
M¥§T's Avatar
Default RE: Fluid Question. Need Help.
What color is your coolant?
Old Jan 29, 2008 | 09:13 PM
I don't know. Where do i check?
Old Jan 29, 2008 | 10:25 PM
AudimaniaA4's Avatar
That white container with orange fluid is yor coolant tank. See picture below.
[IMG]local://upfiles/46647/819B866F0A6042EB8D2756FC19B5153E.jpg[/IMG]
Old Jan 30, 2008 | 12:26 AM
dankhound's Avatar
Brake fluid is yellow but you probably would have noticed the pedal sinking if you were leaking brake fluid.
Old Feb 1, 2008 | 08:07 PM
My coolamtg is green. Where do i check the break fluid level?
Old Feb 1, 2008 | 10:30 PM
typej's Avatar
I recently had ayellowish clear liquid leak in that same area that turned out to be power steering fluid. Is it a thickfluid or thin like water?And, I am surprised to hear that your coolant is green! Sounds like you may have glycol-based coolant in there; I think that's a no-no for our cars. Can you pull the belly pan and get a better look? I am a newb, but I am trying to help. PM me if you have questions for me. Good luck.
Old Feb 2, 2008 | 04:16 AM
The liquid leak is a thin yellow color. What kind of coolant should i be using? I live in a high elevation where right now its snowing and the temperature can drop to minus degree. Which coolant should i use?
panda1r
Aug 25, 2011 03:09 PM
sollyd25
Jul 28, 2011 10:08 AM
fast euro
Apr 4, 2011 08:12 AM
yellow_submarine
Feb 3, 2011 04:25 AM
JohnnyBravoA4
Oct 28, 2007 01:45 PM
