Flush of cooling system
Old Jan 18, 2007 | 04:16 PM
controllerzhu's Avatar
Default Flush of cooling system
When you flush the cooling system can one use a product like a super flush bought at autozone etc.., or just use water and flush twice or more?
Thanks, Randy
1998 A4 2.8 (Just begining to upgrade/mod )
Old Jan 18, 2007 | 09:02 PM
CRAZYHAWK's Avatar
Default RE: Flush of cooling system
If you have origonal G-12 in there, flush with water.
Old Jan 19, 2007 | 12:20 AM
Thanks, thats whats in there but I thing I have a heater core blockage since no heat from the heater. I'll flush it twice and put G12 in again. I recently had the timing belt done along with the water pump/thermostat etc. Only after the first cold spell here in Houston did I notice no hot air. Thanks again
Old Jan 19, 2007 | 09:47 AM
david9999's Avatar
You may just have an airlock in the coolant line to the heater core. Bleed the line.
If that doesn't help, borrow a vagcom and check the HVAC system for codes.
Old Jan 19, 2007 | 11:48 AM
Did a quick bleed by letting air out of the resevoir, got some warm air now. So an air block is probably the problem. Thanks for everyones advise.
Dustinxiii
Nov 18, 2019 09:08 PM
rowesouth
Jul 10, 2014 07:20 AM
Msnickbroderick
Jan 24, 2011 05:54 PM
Broncoman75
Dec 23, 2008 12:56 PM
ne2q 73
Dec 24, 2007 09:08 AM
