FMIC
Old Oct 31, 2006 | 09:59 PM
khj677turbo's Avatar
Default FMIC
Has anyone installed the SPP/RaceTecEngineering Front Mount Intercooler B5
??? Supreme Power parts sells this and says the bumper wont need cutting.
Is that true? ANd its also quite cheap thus the appeal.
Old Oct 31, 2006 | 10:26 PM
swift_A4's Avatar
Default RE: FMIC
what is "quite cheap?" i know the racetec FMIC is $899 through rennart.com and i know there is very very minor trimming needed to make it fit under stock bumper
Old Oct 31, 2006 | 10:32 PM
BadLuckAudi's Avatar
Default RE: FMIC
unless its a tiny *** intercooler some cutting will be required in like 99% of all FMIC setups
Old Nov 1, 2006 | 12:19 AM
Default RE: FMIC
well 825 from supreme, thats not too bad compared to like a 1000
what about having an intercooler fabricated for the car, do you
guys have any experience with that?
Old Nov 1, 2006 | 06:19 AM
A4nicator's Avatar
Default RE: FMIC
ORIGINAL: khj677turbo
Theres nothing that says it couldnt be done. As long as you have piping made to fit properly. What about the DV?
Old Nov 1, 2006 | 06:27 AM
Default RE: FMIC
you can run the stock turbo outlet hose only rotated and then you dont have to worry about the Dv it will just be stock spot... IMO you can make a kit for alot less than you can buy one
Old Nov 1, 2006 | 07:42 AM
chaos92287's Avatar
Default RE: FMIC
wut kind of shops can custom make the piping? cuz i wanted to get a core off ebay cuz the guys around here say some of them work great and tested them with a compressor at 50 psi w/ no problems
Old Nov 1, 2006 | 10:12 AM
dafrazi's Avatar
Default RE: FMIC
I installed the RaceTec FMIC on my car 2 weeks ago.
I didn't have to trim the bumper or the bumper support but you will need to cut out a chunk of the radiator support.
You can keep your fog lights but you will need to trim the back of the lower grills to get them to fit over the piping.
I need to trim a little material off the secondary air pump bracket but haven't doen it yet. The system works fine as is but it looks like there could be problems down the road due to the couplings rubbing against the bracket if I don't trim the bracket up now.
Choas...there is nothing functionally wrong with the ebay FMICs. The issues are when it comes time to install them. The problem with the B5 is the lack of space to in which to install a FMIC behind your stock bumper.
Any muffler shop could put you some piping together.
Old Nov 1, 2006 | 11:27 AM
docurley's Avatar
Default RE: FMIC
I did one great bit of kit and I got it in a GB[:-]
[IMimageG]http://i6.photobucket.com/albums/y224/docurley/Audi%20Project/FMIC11.jpg[/IMG]
Old Nov 1, 2006 | 12:03 PM
chaos92287's Avatar
Default RE: FMIC
ORIGINAL: dafrazi
hmm i see. so are the ebay ones just bigger than say a racetec or greddy one?
