forge 007 dv tuning
Old Nov 27, 2006 | 09:14 PM
EliteTuning1's Avatar
Default forge 007 dv tuning
i have an 01 a4 1.8t with giac-x chip and dv, im running around 15psi and spiking 18, my diverter valve came with the tuning kit to change out when running higher psi, but i dont remember wich color is in wich psi range and if i need to change colors. i tried searching couldnt come up with anything.
Old Nov 27, 2006 | 09:24 PM
chaos92287's Avatar
Default RE: forge 007 dv tuning
in PSI
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
or in bar
Green: 0.3-1.03 Bar
Yellow: 1.03-1.58 Bar
Blue: 1.58-2.06 Bar
Red: 2.06+ Bar
Old Nov 27, 2006 | 09:26 PM
so do you think i should put the yellow one in or no..... and does it make any sound difference or performance differance at all
Old Nov 27, 2006 | 09:29 PM
swift_A4's Avatar
if you use the strongest spring it will not recirculate the air the spring will not be moved by the air. go w/ yellow like you said definatly.
Old Nov 27, 2006 | 10:38 PM
tooxtreme8813's Avatar
if your not expirencing any boost issues or problems holding boost leave it alone, i still have the green spring in mine and I spike at 23psi and hold at 19psi and have no problems
Old Nov 27, 2006 | 11:53 PM
TeeterTawter's Avatar
tooxtreme8813 Date 11/27/2006 7:38:13 PM
I have found that the yellow spring was less spikey but didt let me hold enuff boost (15psi) , green one i have found to be more spikey but lets me hold more boost (18psi).
Old Nov 28, 2006 | 02:45 AM
yeah i had the same problem yellow doesnt hold as much but less spiky(18psi) green hold a sh!tload more for me(23psi)
Old Nov 28, 2006 | 06:22 AM
socal_A4's Avatar
Yea I spike 23 and hold around 18 with my green spring on X chip tuning...
Old Nov 30, 2006 | 02:00 AM
AudiTurbo's Avatar
Well i have a 98 1.8tqm with giac and n75j and i fall down to around 8 at redline....should i go back to the green spring?
ECS Tuning
B7 Models
Aug 7, 2020 02:50 AM
ECS Tuning
Aug 1, 2014 10:52 AM
Darkcolla
Sep 4, 2007 11:06 AM
.clipse
Aug 1, 2007 03:13 PM
Palle
Jun 27, 2006 02:19 PM
