found oil temp sender fix
Old Mar 10, 2007 | 05:06 PM
breeze.12's Avatar
Default found oil temp sender fix
oil temp guage always stayed seated at 150 deg. and never moved, today I removed it from the bottom of the oil pan and cleaned it. a little bit of sludgy oil came from the very small oil passage holes located at the base and the tip of the sensor. just cleaned it with brake cleaner and removed debris with compressed air and bingo, works great. these holes are so small it looks like even the smallest particles could plug and cause malfunction.
hopes this helps.
Old Mar 10, 2007 | 05:09 PM
onepoint8tee's Avatar
Default RE: found oil temp sender fix
Thanks... So I take it you need to drain your oil before doing this right?
Old Mar 10, 2007 | 05:13 PM
breeze.12's Avatar
yes,or just get ready to catch the oil when you pull the sensor, it will come out fast.
mojocvh
Oct 6, 2013 08:13 AM
gstevens26
Jan 9, 2010 10:34 AM
bosnianac
Mar 5, 2008 11:14 AM
BFlan2001
Jul 7, 2006 02:57 AM
haveaseat
May 23, 2006 11:54 PM
