Sponsored by:
Sponsored by:
Front diff fluid?
Old 02-28-2006, 02:41 PM
DLC1.8T's Avatar
Default Front diff fluid?
Can someone tell me if the front differential shares the same fluid with the auto transmission? Or is that just the ones with a 5speed manual?
I'm thinking about changing the center/rear diff fluid with mobil 1 75w90, but I'm not sure about the front one. Thanks for the help!
Old 02-28-2006, 05:47 PM
Default RE: Front diff fluid?
automatic transmission uses VW ATF and front/rear use 75w90 synthetic
manual transmission uses 75w90 synthetic for the lot.
Old 03-01-2006, 02:31 AM
dankhound's Avatar
Front and center diffs are housed with the transmission. The rear diff is a seperate unit.
Old 03-01-2006, 12:37 PM
DLC1.8T's Avatar
ORIGINAL: dankhound
So does the fluid have to be changed for each of these seperate, or when you get the atf fluid changed it takes care of all three? I changed the oil over the weekend and I didn't see a plug to fill the front and center diffs. The rear one looks like it should be easy enough.
Old 03-01-2006, 03:59 PM
1 of 1
[IMG]local://upfiles/12092/BD4B2D3C980E4682BA6F21954410126F.jpg[/IMG]
pinion
05-01-2015 08:05 AM
jlight113
12-16-2012 09:31 PM
powersmokin
04-15-2008 08:56 AM
mpower1226
12-26-2007 03:27 PM
pitobaby76
11-29-2005 03:08 AM
Quick Reply: Front diff fluid?
