Front Left turn Signal
Old Oct 7, 2004 | 12:35 AM
FezA4's Avatar
Default Front Left turn Signal
Hey all,
Lately my font left turn signal has been going out. My car will "tell" me that its out. Only after getting out of the car and "love tapping" the entire headlight can i get it to work. It might jus be loose, or it might be the actual light is messed up. Anyone else have this problem??? Or am I just that special person again???
Old Oct 7, 2004 | 01:24 AM
Jestnomen's Avatar
6th Gear
Default RE: Front Left turn Signal
I'd suggest removing your headlight, and popping your turn signal base/bulb out. Turn your signal on, and wiggle the wires around untill you can get it to fail. Probably just an open in the wiring or a bad connection.
Old Oct 7, 2004 | 05:05 AM
SlimChriz's Avatar
actualy most likely you filament is broken and by tappin it your makin it reconnect temporarily. Ive had this happen a few times.
sometimes it will atach itself to the other filament in the bulb and it will be real bright when your parkin lights are on and wont blink.. this is because the 1197 bulb is a duel filament bulb basicly two bulbs in one
Try replacing the bulb if that doesnt work buy a new car
Old Oct 7, 2004 | 09:34 AM
david9999's Avatar
Alternatively, instead of turning left, make three right turns
JEPartrick
Jun 25, 2013 12:38 PM
abedel2
May 13, 2009 07:53 AM
audi_a4_2003
Mar 26, 2009 07:27 PM
garywinton
Nov 14, 2008 08:04 PM
wutafobbb
Apr 15, 2008 10:23 PM
