frontmount problem
Old Mar 9, 2007 | 08:03 PM
EliteTuning1's Avatar
Default frontmount problem
i hooked up my frontmount today and just took it out for a spin and it seems it put me in limp mode. why is this? it wont boost past5psi. also what should i do with the sensor that plugs into the stock intercooler?
Old Mar 9, 2007 | 08:18 PM
MissionCtrl's Avatar
Default RE: frontmount problem
that would be why you are only boosting to 5psi. you aren't in limp mode technically. the thing that was plugged into your stock smic is your MAP sensor. since it isn't getting a reading of pressure from the inside of your i/c it makes you run at 5psi. as long as you can find some place in the piping/intercooler to jimmyrig it in your problem will be fixed.
Old Mar 10, 2007 | 12:24 AM
Lazer Viking's Avatar
yea.. it deffinatly has something to do with your map sensor
Old Mar 10, 2007 | 06:57 AM
BadLuckAudi's Avatar
yea what did you do with the map sensor you need to have a bung welded on to the pipes so the map will hook in.. if you dont have it hooked up I have one of the weld on bungs around here somewhere id sell ya
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
Audi_97
May 9, 2008 12:26 AM
montoyajohnathan
Nov 27, 2007 06:02 PM
EliteTuning1
Jan 22, 2007 02:40 PM
