Fuel delivery problem
Old Aug 31, 2005 | 05:01 PM
daz's Avatar
daz
Default Fuel delivery problem
Here's hoping someone can help.
I've recently got a Audi A4 2.5TDI Quattro Avant.
I've done a few hundred miles in it and the other day I popped down the shops, left it for 30 minutes and when I got back it started briefly then died. Would crank but not turn over.
The nice bloke from the RAC checked the fuel system and suspected a pipe loose in the tank as there was no fuel getting to the fuel filter.
As the fuel guage had also only been registering half full after filling up and the RAC bloke thought someone had been inside the tank I decided to investigate.
On opening the inspection cover the black connector on the fuel return side in the tank fell in two pieces and was held together with a tiewrap due to some bodging but everything else looks extremely new. The fuel sender appears to have been fouled by a hose and now seems to work ok but would the black connector on the rear of the inspection cover cause a failure to pump fuel if it came adrift?
It is possible that I dislodged the bodge repair when I openned the cover but could the pressure in the system cause this?
Other than the pump in the tank (Which incidently is on the fuel return side!!!) is there anything else worth checking?
Once I connected everything back together and primed the fuel system by filling the filter with diesel it started and appears to be ok at the moment. Also does anyone know what the technical term for the black connected on the underside of the inspection cover is called? It it pushed on the lid with a clip either side and is two piece with 2 hoses connecting to it.
Thanks in advance
Darren
austinwasthere
Mar 28, 2011 09:33 PM
austinwasthere
Mar 28, 2011 03:02 PM
Prizmatik
Oct 20, 2009 04:36 PM
audidude89
Jul 1, 2009 02:04 AM
bleak17
Mar 16, 2008 12:00 AM
