Fuel pressure gauge failed or ?
Old Apr 4, 2006 | 07:33 PM
prodrive's Avatar
Default Fuel pressure gauge failed or ?
Hi guys.When I check my fuel pressure gauge at idle I saw 45 psi on it but I am stock. Should't it be around 55 psi ?
Old Apr 4, 2006 | 07:36 PM
aRIf's Avatar
Default RE: Fuel pressure gauge failed or ?
Stock is 4bar I think so it is about 48psi.
you have an adj. right ? did u adjust it right?
Old Apr 4, 2006 | 07:44 PM
prodrive's Avatar
yes I have adj.one but I didn't installed it yet ,just the gauge right now.You mean 58 don't you ?
Old Apr 4, 2006 | 07:53 PM
aRIf's Avatar
yeah 58, not 48.
Old Apr 4, 2006 | 08:01 PM
TomRitt's Avatar
thats with the vac line disconnected
prodrive's Avatar
ORIGINAL: aRIf
yeah 58, not 48.
Isn't it the right location for the gauage ? I know your gauge is on the same line but different location will this couse porblem for reading
Old Apr 4, 2006 | 08:07 PM
aRIf's Avatar
is it the hose that goes directly to the fuel rail? if it is, yeah it's on the right location.
the gauce that I have, is very close to the fuel rail, I dunno if it makes any differance.
Old Apr 4, 2006 | 08:14 PM
TomRitt's Avatar
placement makes no difference the reason its reading low is cause its on vac. FP changes with map, so the vac is pulling down the fp, hence why you check it with the vac line pinched, and unplugged and pinched
Old Apr 4, 2006 | 08:16 PM
prodrive's Avatar
ORIGINAL: TomRitt
so you say it's normal ,I will be installing 2871r by the end of April and I have to do the setting for 3 bars.While I was adjusting the FPR should I disconnect the vac line ?
Old Apr 4, 2006 | 08:23 PM
prodrive's Avatar
ORIGINAL: TomRitt
Thanx Tom too fast reply .one more question ,which vac line should I unpluged and pinched ? the one on the intake manifold ?
