Fuse troubles
Old Nov 27, 2006 | 08:00 PM
chaos92287's Avatar
Default Fuse troubles
ok so on my trip back from south fl. i stopped at a rest stop, and when i got back in the car i went to turn on my headlights and they wouldn't turn on. the yellow corner lights work and if i pull back on the headlight stalk my high beams work but they **** off a lot of people while driving[8D] i checked the fuse box but they all seem to be fine. isn't there antoher set of fuses? where can i locate them and does anyone know which fuse would be causing this? o and the middle little computer on the dash is out too, so im guessing its the same fuse. its a 98 1.8TQM btw
Old Nov 27, 2006 | 08:08 PM
techbod's Avatar
Default RE: Fuse troubles
cant see any others
[IMG]local://upfiles/12092/C16E644689EB47AE9E24143D5864CCEB.jpg[/IMG]
Old Nov 27, 2006 | 08:16 PM
acetrebo's Avatar
Could be a bad bulb, but seems kind of strange for both of them to go at the same time.
Old Nov 27, 2006 | 08:17 PM
chaos92287's Avatar
ya i checked all those but aren't there a set of bigger fuses under the dash or sumthin? those got wet a while back and caused my secondary fan to go out so im assuming the same happened with another fuse
Old Nov 27, 2006 | 08:23 PM
chaos92287's Avatar
if it was a bad bulb wouldn't the high beams also not work?
Old Nov 27, 2006 | 08:26 PM
techbod's Avatar
[IMG]local://upfiles/12092/EB0F6FCEAB10499F9C8A3A4461282A47.jpg[/IMG]
Old Nov 27, 2006 | 08:28 PM
chaos92287's Avatar
ooh ya thats what i was looking for Dave. do you know how to get to those fuses?
acetrebo's Avatar
ORIGINAL: chaos92287
I think the high beams are another bulb. I am trying to remember, but it seems like when my left headlight went out, the brights still worked, but not the low beam.
I can check for you when I get home, I'll look it up in the Haynes and look at my headlamps. Mines a 97 1.8 so we should be the same.
Still, both sides going at the same time sounds like some kind of relay. I'll check back later, if no one has answered it for you I should be able to help more once I get to the manual.
Old Nov 27, 2006 | 08:35 PM
techbod's Avatar
#3 fuse/relay plate
[IMG]local://upfiles/12092/1EEFE77B2EFF478B922AA1D571D2ACF4.jpg[/IMG]
Old Nov 27, 2006 | 08:37 PM
techbod's Avatar
if its left hand drive they might be on the other side but not sure
