RE: Gas brand preference, and does it matter?
I use the highest unleaded octane I can get, it's usually 93 but on rare occasions I can find 94. I won't go lower than 92.
Shell 91 but depends on the gas station I'm out. Found 3 close to me that are good 1 is a stright rip that is a shell but family owned so how knows. I just know I get crappy MPG from that one and am forced to use an octane booster to get the MPG to a decent mark. Other then that Shell and Chevron are my to of choice and I will go out of my way to find a good gas station.
Shell is good but has all the additives, BP is good w/o additives, and it matters.
why high ocatne?
well german n/a engines are highcompression which means they can compress a given amount of air more, octane is the resistance to ignition so if you have a lower octane it will ignite due to the heat like in a disel and cause engine knock which is very bad but that dosent ussualy hapen so you get bad performance and mpg and every turbo car uses a higher ocaten because the turbo forcess more air into the engine i use shell 93 bp 93 and mobil 93 and when i go to the track or when i make my friends pay for gas when we go to the southside to pick up i make them put in 100 octane from clark whic is 6 a gallon |
this should have a poll
I've always used Sunoco 94, we have no access to anything else where I live, except off brand Sheetz gas, and...i just dont trust it. Wish we had a Shell.
Correction: Wish we had a Chevron
I use BP at home in NJ. But I'm currently at school in RI and Mobil/Exxon is all I see around here, so I fill up with their 93.
yes our cars are tunned for higher octane ratings, anything less would be uncivilized, well not really but itll cause a CEL or severely retard the timing. also where you get gas matters, cheap isnt always better, i filled up at the dominicks petrol pumps once and my tank only lasted me to about 280 miles, whereas when i use shell or BP i get 300 with a small bit of spirited driving and i can usually still go another 20ish miles before the gas light comes on and i fill up.
Sunoco 94 always. gotta love Canada!
