gauge installation
hey guys just purchaced a boost gauge for my 98 1.8t qu. now on the instruction manual it says to either screw an adapter into the manifold or tap the vacume line. does any one know if i have to tap the vac line directly or is there one where i can screw it in on the manifold? or, which would be even better, does someone have a link to an install setup.
dont want to be a jerk but try using the search... im sure many people have incountered this because this mod is very common. if you cant find anything pm me and i will send you the write up w/pix
just put a t fitting in the vacume line to the fuel pressure regulator. Or a link to a good install guide http://www.audiworld.com/tech/eng32.shtml
I read somewhere (Audizine?) not to tap off of the fuel pressure regulator vacuum line. The write-up said if there is a vac leak it will cause the engine to run lean. Running lean can lead to nasty things such as burned pistons.
