gettin code 17090
Old Jun 13, 2007 | 06:40 PM
surreyrider's Avatar
Default gettin code 17090
Hii ALL
Im gettin a code 17090...
when i put my car in reverse PRND go out when i put it in neutrol they start flashing after a lil while it returns to nornal??
wuts goin on?
2002 a4 1.8 t auto tip
Old Jun 18, 2007 | 12:46 PM
Default RE: gettin code 17090
useless magets!!
Old Jun 18, 2007 | 09:31 PM
auditech79's Avatar
Your car is going into transmission limp mode, and your post with yourhorriblespellingis usless, learn the english language.
You need to change the PRNDL switch board under the shifter assembly.
Old Jun 27, 2007 | 06:41 PM
[:@] thanks auditech is this switch expensive....my car isnt under warranty!
Old Jun 27, 2007 | 07:17 PM
auditech79's Avatar
I don't think its that bad, maybe 200-300 range. Just pop up the trim around the shifter, then pop out the four clips around the shifter and lift up the chrome piece around the shifter. That entire piece is what you are changing.
Old Jun 27, 2007 | 07:50 PM
Do u have any pics of this switch as i heard there are 2 switches
Old Jun 27, 2007 | 08:02 PM
auditech79's Avatar
No, its the entire assembly, it has two switches, and a set of magnetic brushes that brush accross the sensor matt that tells the TCM what gear you are in. So if you remove that big chrome plated cover under the shifter you will see an electronic circuit board underneath that, thats what you are replacing, it comes as a whole unit, switches and sensor.
Old Jul 9, 2007 | 06:52 PM
http://cgi.ebay.com/ebaymotors/AUDI-...QQcmdZViewItem
is this wut i need???
Old Jul 10, 2007 | 05:37 PM
Old Jul 12, 2007 | 04:41 PM
Hello, I just found out its the multi function range switch!! Does anyone know the exact location of this switch
getty_iceman
Jul 6, 2015 09:09 PM
getty_iceman
Jun 22, 2015 09:50 AM
audibuyer
Oct 9, 2010 12:13 PM
impaler2383
May 11, 2006 12:15 AM
1.8T5spd
Jun 4, 2004 08:32 PM
