GETTIN THE K04 PUT IN THIS FRIDAY!!!!!!
Old Apr 10, 2007 | 03:34 AM
  #31
chaos92287's Avatar
Default RE: GETTIN THE K04 PUT IN THIS FRIDAY!!!!!!
ORIGINAL: NuYorka103185
I am puttin in the Borg Warner K04 I'm not sure which model that is. I am doing the FMIC probably 2 weeks later and then TT 225 injectors and the 5 bar fuel regulator. You dont need the intercooler unless you are doing an aggressive file. I am gonna confer with the evoms performance specailist and if they greenlight me Im doing the J-31 file. Im just happy to be finally getting the bigger turo put in. After those mods, It time for coilovers, kit and all the other goodies. Another rung on the ladder gentlemen, another rung on the ladder.
are you sure j31 requires a 5 bar fpr? pc-16 requires a 3.2 bar fpr.a 5 bar fpr is way too large for any kind of power a k04 will be producing.
Old Apr 10, 2007 | 03:38 AM
  #32
A4Rollin's Avatar
i had the K04 file with a 5bar fpr and it was recommended that i had it put on (dont know why). Had no problems at all with it on tho
Old Apr 10, 2007 | 03:53 AM
  #33
chaos92287's Avatar
ya when i first started researching pc-16 a lot of people said 5 bar fpr. but then i spoke with a few guys who had gone pc-16 and to a few tuners and they all suggested i get an adjustable fpr. each car is slightly different but most find 3.0~3.4 bar to be the best. most just keep the stock 3 bar fpr and never have any problems but to get every pony you can out of the setup some guys put on adjustable ones. only someBT setups require a 5 bar fpr
Old Apr 10, 2007 | 05:08 AM
  #34
onepoint8tee's Avatar
what bar fpr you use partly depends on what size injectors you have. K04 kits that are sold, commonly by AWE and Neuspeed require the use of a 5 bar fpr.
4 bar is thestock fpr
Old Apr 10, 2007 | 07:39 AM
  #35
AteUrV8's Avatar
so do you ever plan on putting in injectors... whats stock size, like 280cc lol... get that fpr and get some 550's and watch that turbo truly come to life...
hows the stock fuel pump on audi's??? would it be recommended to do a walbro 255, or possibly 190? not too educated on audis stock fuel system.
Old Apr 10, 2007 | 08:39 AM
  #36
chaos92287's Avatar
5 bar fpr walbro 255 fuel pump and 550cc injectors for a k04??? r u kidding me?thats at least gt2871r territory. u guys give the k04 waaay too much credit. pc-16 requires a 3~3.4 bar fpr and 310cc injectors.
Old Apr 10, 2007 | 01:39 PM
  #37
ORIGINAL: chaos92287
Ya, i was just saying the basic k04 chip requires a 5 bar fpr. Dont you have the basic k04 chip? Are you still using the stock fpr?
Old Apr 10, 2007 | 02:30 PM
  #38
akielb's Avatar
This Neuspeed link says that any car with a 1 bar or higher chip should have a 5 bar FPR. I've seen this statement on other websites. are they incorrect?
maybe I'm totally misunderstanding what the FPR does
Old Apr 10, 2007 | 02:53 PM
  #39
ORIGINAL: akielb
If you look in the fine print where neuspeed says that, it says its only for vehicles that sustain high speeds/rpms like at the track. K03 chips dont need any additional fuel adjustments over stock unless its a custom tune.
Old Apr 10, 2007 | 05:16 PM
  #40
chaos92287's Avatar
ORIGINAL: onepoint8tee
i have the stock fpr in the car (which i thought was 3 bar not 4 bar, i'll research it a little more) with thegaic basick04 chip, no upgraded injectors. and i talked a lot with some guys on audizine that are running pc-16 and one hadhis fpr set to3.2 bar and another was using the stock fpr. so why would the basic k04 file (which puts out likea little over halfof what pc-16 does) require a bigger fpr?
