GIAC
Old Jul 3, 2006 | 03:44 AM
tooxtreme8813's Avatar
Default GIAC
I had my car chipped 4 days ago and I can really feel the difference in power. Its great but when I put the pedal to the floor I get some boost surges but they seem to come and go. I have a forge DV and I switched the spring to a higher one but i still get the boost surge. I thinking of getting a new N75 valve as I heard they are supposed to cure boost surge in chipped cars. Or can it be the ECU just getting used to the chip? How long should it take for it to get broken in ?
Old Jul 3, 2006 | 09:35 AM
david9999's Avatar
Default RE: GIAC
Give it a week or about 300 miles
Old Jul 3, 2006 | 10:27 AM
RLB6's Avatar
Default RE: GIAC
ORIGINAL: tooxtreme8813
I would venture to say change the N75 valve because while the DV is a new Forged 007 unit, the N75 could only be the other cancer.
Old Jul 3, 2006 | 01:36 PM
JettaRedII's Avatar
Default RE: GIAC
Put an OEM 710N DV in if you have the Forge 007P. The piston DV is a little slower to respond than the 710N. The N75H valve worked fine with the GIAC K03 program, but the K04 programs do NOT like the N75H or N75J.
Old Jul 3, 2006 | 02:54 PM
kaklexicon's Avatar
Default RE: GIAC
I have the same surging issue.. I'm chipped with Giac, and have the ecs-tuning n75k race valve.. and it still surges. I dont' know what else to try.
Old Jul 3, 2006 | 03:21 PM
Beer Mod's Avatar
Default RE: GIAC
^^^ It could be that you are floating the shaft on your turbo due to over boost (this will cause compressor surge). How many miles on your turbo? How many psi are you running?
Old Jul 3, 2006 | 03:27 PM
kaklexicon's Avatar
Default RE: GIAC
Yea I think you're right it probably is the trubo.. I think it's going to blow soon. It's at 96000 miles, boosting around 16 psi.
mikekehler
Oct 6, 2009 12:38 AM
disbealig
Jan 5, 2009 01:25 AM
daness373
Feb 11, 2008 04:12 PM
Brandon2000s4
Sep 14, 2006 03:08 AM
dan
Jun 18, 2006 10:28 PM
