going above 1BAR (14.7psi)
Old Sep 11, 2007 | 09:44 PM
  #41
cincyTT's Avatar
I'm make believe
Default RE: going above 1BAR (14.7psi)
and i thought is was just a crappy looking southwestern style pattern LOL
Old Sep 11, 2007 | 09:46 PM
  #42
kemp_travis's Avatar
y would it run like **** with a blow off valve not recircing?
Old Sep 11, 2007 | 09:48 PM
  #43
cincyTT's Avatar
I'm make believe
cause its not the right kind, so it would suck *****
Old Sep 11, 2007 | 09:50 PM
  #44
onepoint8tee's Avatar
ROFL at everything happening in this thread.
  #45
what if you run a Y fitting from the bov....so one goes into the recirc and one blows out...?
Old Sep 11, 2007 | 09:57 PM
  #46
kextyn's Avatar
ORIGINAL: kemp_travis
The air will follow the path of least resistance most likely and exit into the atmosphere.
Hasn't the whole DV/BOV thing been stomped into the ground already?
Old Sep 11, 2007 | 09:59 PM
  #47
kextyn's Avatar
LOL, I just realized I missed a huge no-no with that y fitting. If you have a y fitting so that air can go either out to the atmosphere or back into the intake system you gave yourself a nice boost leak.
Old Sep 11, 2007 | 10:00 PM
  #48
oh ya....good point...hah
but i just dont understand why it would run sh!tty with it not recircing
Old Sep 11, 2007 | 10:02 PM
  #49
You need a valve that doesnt vent at idle, and being AEB engine, you also need one that isnt 100%vta. The newer engines can adapt better for the missing boost that the ecu is expecting to be recirculated. You really need to take an hour or so and just read the stickies. They are stuck to the top for a reason.
Old Sep 11, 2007 | 10:04 PM
  #50
i didnt know it vented at idle...
and now tht im on 13-14psi, i can hear it when shifting or putting in the clutch...
