Got more codes
Old Oct 13, 2007 | 01:55 AM
Trey25's Avatar
Default RE: Got more codes
I've cleaned the MAF three times in the past 5-6 months, about a month ago last time. Still no improvement. On the VAG you can check if all the sensors are working within parameters right? I guess I won't know exactly whats going on until then. Either way the car has 130k so I'm changing the precat sensors.
Old Oct 13, 2007 | 02:01 AM
auditech79's Avatar
You can also monitor the MAF sensor as well as the O2 sensors, the O2 sensors are much easier to identify malfunctioning though. What you would want to look for in the MAF is the g/s at idle and WOT.
At idle it shouldn't be any higher than 3.2 g/s, when flooring it you want to look for spiking numbers and fluxuations.
Old Oct 13, 2007 | 02:10 AM
Trey25's Avatar
Is there a way to measure voltage or resistance on the MAF using a digital multimeter? I did it with the precat sensors but couldn't get a reading with the MAF.
Old Oct 13, 2007 | 02:19 AM
auditech79's Avatar
Audi doesn't have a test procedure for it in elsa web, i only see tests for measuring voltage to the sensor, ground, and signal, you can't measure resistance of the sensor itself. Or at least i don't have a spec for it.
Old Oct 13, 2007 | 02:28 AM
Trey25's Avatar
I see. Well thanks for the help. I'll get the car on a VAG and see what happens from there.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
