Got a question on some codes, can you help??
Old May 27, 2011 | 05:17 PM
audiblaze's Avatar
Default Got a question on some codes, can you help??
Hello everyone, I have a Bentley manual and also a vag com cable with vcds. I can't figure out some of these codes...
To start off my car is:
1999 Audi A4 b5 1.8t (AEB) Quattro, Auto Trans with Tip Tronic.
150k.
Address 02: Auto Trans
2 Faults Found:
00296 - Kick-Down Switch (F8)
29-10 - Short to Ground - Intermittent
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 08: Auto HVAC
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 01: Engine
2 Faults Found:
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
Readiness: 0000 0101
I have just replaced, All brand new coils, bosch oem plugs, Ignition control module, Tran's fluid and filter, Differential Fluid, Pressure regulator Valve, Downpipe and Flex pipe, Exhaust gasket's. I do have a 3inch test pipe installed, im sure that is causing the 16806 code under engine codes. Is the fuel trim caused by a bad MAF? Most of all any help on the tran's codes..? Or the Ignition timing off in HVAC.
Thanks everyone! Let me know anything that might help.
Nevalite
Feb 12, 2011 02:56 AM
adidasallstarguy
Nov 30, 2008 04:44 PM
domvr6
Mar 26, 2008 10:22 AM
bpguitarbiker
Oct 17, 2007 11:01 AM
fenderstrat1184
Jun 23, 2007 05:06 PM
