New VAG user with codes and a Question
my vag is giving me codes of 00753 and 00526, and I am also wondering, I think the first one has to do with a wheel speed sensor and I was wondering if that is the same as vehicle speed sensor, thats what comes up when i search autozone. Everyone's help is appreciated,thanks.
Those do not look like VAGCOM codes for Audi they look like std OBDII codes --
00526 is the brake light switch for bothe OBDII and the ross-Tech Wiki
while and 00753 is right center vent switch while OBDII and Ross- Wiki dosen't list it
do you have the P codes?
Here is where I was getting the information from, just copy and pasted to here, I hope this helps.
VAG-COM Version: Release 409.1-US
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01: Engine
Controller: 8D0 906 266 A
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01242
Shop #: WSC 23247
No fault code found.
Readiness: N/A
Address 02: Auto Trans
Controller: 4A0 927 156 AL
Component: AG4 01F 2.8l2V USA D25
2 Faults Found:
00753 - Electrical Connection to Wheel Speed Sensor
35-10 - - - Intermittent
00526 - Shareware Version. To Decode all DTCs
27-00 - Please Register/Activate
Address 03: ABS Brakes
Controller: 4D0 907 379 J
Component: ABS/EDS BOSCH 5 7679
Coding: 0265109024
Shop #: BB 37679
Address 01: Engine
Coding: 01242
Shop #: WSC 23247
Readiness: N/A
2 Faults Found:
Coding: 0265109024
Shop #: BB 37679
I think mine is that OBII reader I thought I was getting the VAG, Ross Tech won't let me check much since its the trial version, i thought I saw someone talking about a free program one time on here, if so do you know the name?
In the Bentley Manual it says 00753 is the Electrical Connector/Wheel Speed Sensor and all the rest of them have a P code but this one doesn't. I have a Diagnostic Trouble Code Table I wish I could show you but there is no way to upload it to here.
