Gpopshop K04 is in the car!!
Old Mar 18, 2007 | 12:18 AM
The Bishop's Avatar
Default Gpopshop K04 is in the car!!
Got the turbo in and working, Actually alot easier than I thought it would be. I took lots of pictures, and the DIY is coming. So far the turbo is much louder, kinda sounds like a semi. I am still breaking it in so I haven't gone full throttle yet, but all I have to do is just crack the throttle and I get like 5psi. After removing my old turbo I think I know why I wasn't getting the performance I used to. The exhaust side has multiple cracks in the housing. and the wastegate flap was loose. Very happy to have a new one.
Check out the cracks in the last picture.
[IMG]local://upfiles/23901/9D3475E0A684404BB36C1976F6485847.jpg[/IMG]
[IMG]local://upfiles/23901/68CBBAD5FAA540248D7C2E5FE4197E65.jpg[/IMG]
[IMG]local://upfiles/23901/97D3B25A6EED4883AC0DB9F67FE1CCC4.jpg[/IMG]
Old Mar 18, 2007 | 12:33 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Gpopshop K04 is in the car!!
woot looks nice. what kind of break in are you talking about?
Old Mar 18, 2007 | 12:35 AM
The Bishop's Avatar
I don't really know if you have to break in a turbo, so I didn't really drive it that hard. I don't know, but I'd rather not blow it up yet.
Also checl out the difference in the compressor wheel.
[IMG]local://upfiles/23901/F00714D55F2B44639F4DED5635369732.jpg[/IMG]
[IMG]local://upfiles/23901/8C7C930098414448A47034C3C81B2A92.jpg[/IMG]
Old Mar 18, 2007 | 12:44 AM
Jeff's Avatar
i have never herd of a break in peroid before
Old Mar 18, 2007 | 12:45 AM
The Bishop's Avatar
I don't know if there is, just wanted to be safe.
Old Mar 18, 2007 | 12:50 AM
theguy1084's Avatar
Dont the K04s hove the same compressor as the k03. The only difference is the fins on the turbine side. I got my tubo from gpop and didnt bother breaking it in. I havent had a problem yet
Old Mar 18, 2007 | 12:52 AM
turbo kraut's Avatar
Tech Guru
that looks purty
The Bishop's Avatar
That's exactly it, it's just a different compressor fan wheel (however you want to say it.
Old Mar 18, 2007 | 01:15 AM
onepoint8tee's Avatar
Also has beefier journal bearing so it can run higher boost reliably.
Do you notice any power increase even though its running on a k03 chip?
Old Mar 18, 2007 | 01:25 AM
The Bishop's Avatar
A bunch so far, I'll let you know more after I do more testing tomorrow.
